Low oil level after 3400 miles?
Not sure if this is the right page for this , if not please move , so I bought my 23 BS in Nov 23 new at a dealership in texas that will remain unnamed for now , after 1200 miles I had fast lane do the 1st oil change ,even though they recommended 5k-6k miles , that was back in Jan and I didn't ck the oil after the oil change ( shame on me ) a couple of days ago while filling up with gas I cked the oil and was stunned nothing on the stick , at least not the part with the little holes in it , I rechecked it three times to make sure , the dealership was only a couple of miles away so I took it to them and explained the problem , so fastlane pulled it in and I could see the tech as there's a window fa ING the waiting area , 3 different techs are looking under the hood and then one pulls the hose with the oil fill nozzle over for about 10 seconds , then then main tech( I assume) sits in the driver's seat with a scan tool for at least 20 minutes, several other techs walk up to him and talk during this time , finally they raised it up and looked for leaks , none found , when the tech wrote up the order it said " added one half quart oil checked for leaks none found " , they didn't charge me anything, but I'm calling BS ,there's no way it was only 1/2 quart low , I noticed my mpg has been getting worse over the last 3 weeks , I think they under filled the engine when they did the oil change back in Jan, that was 2600 miles ago , I understand some of this is own me for not cking the oil sooner but on a new car I wasn't concerned with cking as often, is it possible that the tech was erasing data on the computer in that 20 minutes he was in the cab , and what are my options.
Hi Ronald! I can look into your Bronco's leak concern on my end. To get started, could you please send a private message over with the name/location of your local Ford dealer and your Bronco's VIN?
