Leaking Brake Light Housing
NJBronco
Min
NJ
Just hit 2k miles but first noticed it under 1k miles. I thought it was just some condensation but started noticing it bead up. I started noticing it was happening with low to severe rain when the leak occurs. Dropped into my dealer and they ordered the parts to fix it. Simple issue with a simple fix.
Ford Bronco Sport Leaking Brake Light Housing 20211002_131932
Ford Bronco Sport Leaking Brake Light Housing 20211002_131917
Rgill
Vegas
Las Vegas
2011 Toyota FJ Cruiser
For anyone else that it happens to, what is the part and fix?
Buzziant
Cris
Hawaii
I saw this on the second day I brought it, it looks like the seal it's located more on the middle instead on the edge so anything below it may look like it's leaking, I guess bad Ford design.
The black line where I think the seal is.
Ford Bronco Sport Leaking Brake Light Housing 20211002_131917~2
NJBronco
NJBronco
Min
NJ
You are so right....... the dealer ordered a replacement part but I guess this will always happen because of design.
brockdog12
NTX
Looks like it’s outside the seal, does it leak into the cabin area? May just be condensation from temperature changes. I have to dry that area a few times after I wash mine, it holds water.
Hi there! Can you send us a message with your VIN and Ford dealership name? I’ll look into this on my end. Thanks!
NuBronco
James
Orlando, FL.
I have this same issue, dealer changed the rear break light and it’s leaking again. It leaks inside the vehicle once water builds up enough in the metal door until it reaches its first open hole. I took the back hatch upper panel off to watch it. It’s going back to dealer again tomorrow to see why they can get it fixed. It’s a 2021 Big Bend model. Any advice would be greatly appreciated.
Hello there! Can you send us a private message with your VIN and Ford dealership name? I’ll look into this leaking brake light concern on my end. Thanks!
NJBronco
NJBronco
Min
NJ
hf995
New York
The past few days in the NYC area have been gloomy and wet, and I happened to notice that my center break light has a similar condition as @NJBronco . The inside perimeter between the setback gasket and the outside edge is filled with water and/or condensation, along with a significant amount of dirt or sediment accumulation in some areas.
To address this issue, I decided to pour some water over the top end of the Dole light and observed the pools and condensation inside flow and slosh around. Unfortunately, this did not dislodge the dirt accumulation, and there is still plenty of water trapped in that void. I am concerned about what might happen next time the temperature drops below freezing and how the dirt will ever get out without removing the entire enclosure.
I am wondering if anyone or @Ford Motor Company has any definitive fixes to report since the last post. It seems like all the dealership will do is replace the same part, which will eventually have the same issues. Any thoughts or updates would be greatly appreciated. Thank you!
Ford Bronco Sport Leaking Brake Light Housing IMG_1800
Ford Bronco Sport Leaking Brake Light Housing IMG_1801
Ford Bronco Sport Leaking Brake Light Housing IMG_1802
Ford Bronco Sport Leaking Brake Light Housing IMG_1803
