Larger tires on 2022 Bronco sport
MedTech
Treavor
Fullerton, CA
2021 Bronco Sport, 1999 C5 Corvette
Is the factory spare okay with the bigger tires if you ever need it or would a larger spare be required as well? Aren't AWD vehicles fussy about tire size? I have even heard never just change one tire on an AWD because the difference in tread height can f-up an AWD system. I know when I had old Ram 4X4, the spare tire had to be the same size (height wise) otherwise you could really f-up the 4WD system.
Dannyp56
Danny
Payson, AZ
2024 Ford Bronco Sport
The donut spare I have is smaller than the other ones.
Bill G
San Gabriel Valley, CA
Seems Ford was okay with @ 1/2” difference in diameter between spare and other tires. The “full size“ spare was 225/65R17 (28.5”) on the BL and the optional tires were 235/65R17 (29.0”). If you put 245/65R17’s (29.5”) on the ground you should be fine with 235/65R17 as a spare, and it will fit in the spare well (at least on pre-2025’s).
Reactions: Me3
Deathmiester
Idaho, USA
2022 bronco sport
I believe that the factory spare will be fine. If needed, it would be on for as short a time as possible. Thanks for the thoughts.
