just got mine and have a stupid ?
ck122
chad
michigan
22 bronco sport 1950 chevy style line deluxe
is the big bend the same ride height as the outer banks and badlands thinking on putting on bfg ko2 245 65s
thekingprawn
Dustin
Kingston, Wa
Per the tech specs, "Minimum running ground clearance 7.8 (Base, Big Bend); 7.9 (Outer Banks)" and "8.6 (standard)/8.8 (optional)" for Badlands.
thekingprawn
Dustin
Kingston, Wa
Also: Height 70.2 (Base, Big Bend); 70.3 (Outer Banks) and 71.4 (Badlands).
cgparsons1983
Chris
Boise, Idaho
I believe the badlands is the only one with a 1.5" lift but someone can correct me if I'm wrong
Correct. Badlands is the only 2022 Sport trim that is lifted compared to the other trims.
GulfCoastBronco
Topher
Corpus
I’ve also seen some say it’s lifted 1 inch
But OP should be able to put 245/65/17 on a Big Bend with (and I’m pretty sure) or without a lift and be fine
Badlands has factory 1 inch suspension lift and with optional 235 tires about another 1/4 inch more.
