Rpm gauge jumps when decelerating
acapecci
AC
Fort Myers Fl
bronco sport
I have 2024 bronco sport ; i scheduled an appointment to have this looked at but want others input on this.. when i take my foot off the gas and let the car decelerate on its own it jolts like crazy/rpm gauge shoots up… im hoping it isnt an urgent issue and end up stranded on my way to work before i have it looked at. Doesnt seem as severe when driven in eco mode but can still feel it happen
Davexxxx
MO
2024 Bronco Sport, 2023 F150 Powerboost 501A
Because you say it is less in Eco mode and Eco mode affects transmission shifting points, I suspect transmission programming is the culprit.
Do these transmissions have a learning mode? My truck does. I've never had problems but others have complained of rough shifting, cured by resetting it.
Yes, the transmission adapts to driving conditions. Disconnecting the negative battery cable for 15+ minutes should reset the powertrain control module to factory preset.
Davexxxx
MO
Good to know. Thank you.
Besides the disconnect 12V battery cable procedure as Mark suggested, have a look at these:
https://www.broncosportforum.com/forum/threads/resetting-the-ford-8f35-transmission.11466/
https://www.broncosportforum.com/forum/threads/ford-8f35-transmission-relearn-cycle.11467/
I posted some info on transmission reset and relearn but my suggestion is you do nothing on that 2024 - you don’t want to possibly erase any stored codes or alter the behavior - suggest you allow the dealership to look it the issue first
When is your appointment?
Reactions: Me3
acapecci
AC
Fort Myers Fl
bronco sport
Yeah I'm going to wait and hopefully the issue doesn’t get worse , appointment not for another week and a half
