Fuel Leak
DBL-J
Minnesota
Just wondering if anyone else has had a fuel leak in their BS. I have a 2021 OB with 29,000 miles on it and after driving around town and then parking in the garage, I noticed a strong smell of gas with leakage on the floor. The gas mingled with the snow melting on the floor of the garage so not sure where it's coming from...I'm in Minnesota and snow tracks in all the time. It's been at the dealer for the past few days and still waiting to get an answer.
Have you had the recall done that installs a drain tube to address a potential leaking fuel injector?
Is it leaking under the front or rear of the vehicle?
Possibly the known issue with 1.5L - cracked fuel injector
DBL-J
Minnesota
Yes did have the drain tube installed at 9,500 miles... as for where it was hard to tell with the snow falling from the wheel wells and melting after parking inside. The fluid mixed with gas did drain towards the garage door.
DBL-J
Minnesota
If one or more injectors are leaking the dealership will replace all 3 fuel injectors under the applicable CSP which is a one-time program available to 1.5L vehicles under 150,000 miles
Thanks for the reply... I hope this is the case.
