Ford recovery kit
Idontknow
Will
MN
Cross trek and grand caravan
jofer
Unless you have a winch, most of that kit is not helpful. The snatch block and tree trunk strap are only used when winching. They're not useful otherwise.
I'm sure the recovery strap and d-rings in that kit are high quality, but you're paying for a lot of things you can't use there and missing something you'd need (a recovery hitch). You can get a high quality strap, shackles, and a receiver hitch for significantly less that what you're paying for that kit.
If you'd prefer a kinetic rope (aka stretch rope), you can get one for the price of that kit. By and large, though, a recovery strap deliberately has some amount of stretch (which is what distinguishes it from a pure tow strap that isn't meant to stretch). The kinetic ropes stretch far more and will pop things out that would otherwise be much harder, but they're certainly not needed for most cases. They're also pricey and bulky. I'd skip it unless you know you want a snatch rope.
Either way, though, you're going to need a recovery hitch receiver in addition to a strap/rope, shackles, and gloves. Might as well get soft shackles these days, too, as they're not too expensive and avoid an extra piece of steel potentially flying around. Personally, I'd save the points for something else.
Benanza
Ben
NJ
Actually, you can use the tree trunk strap and snatch block without a winch. I have done this personally 2 different ways... A come along is a manual winch, and a lot easier with a couple snatch blocks reducing the strain on my muscles, just takes longer. The other is a high lift jack which is used the same method as a come along but you may need multiple straps.
Just remember slow steady and straight
Idontknow
Will
MN
I appreciate the information everyone.
