Extend door check strap/limiter?
gman62
Northern Ill
Bronco Sport Outer Banks Edition
I would like to be able to open wider one of the rear doors on my BS. Is there a simple way to extend the door check? What would happen if I just unscrewed it from the door frame and did not have it hooked up?
Thanks
Reactions: Jrl
Thanks
Great question, let us know if it can be done .
Ford Bronco Sport Extend door check strap/limiter? 0844DF64-55B5-43F9-A85F-830D8CB6F1BB
DaveInSA
Dave
San Antonio, Texas
2021 Bronco Badlands
I'd be extremely careful, if it 'over opens' you'd end up scratching / bending body panels.
gman62
Northern Ill
I know for example on the Honda Ridgeline that you can switch out to an extended Door Check that give the door the ability to open at more of a 90 degree angle.
Reactions: Jrl
