Driver and Driver Passenger Side Windows re-opening after shutting
mdwheaton
Matthew
Anyone else have this issue occasionally ?
21 OB BS, I've done a full SYNC restore, still happens from time to time.
I push/pull all the buttons to close, and the windows go up, seems to seat properly, then re-opens.
Sync doesn’t control the window operation for up/down
I’m not sure what window options your vehicle has but perhaps try the Resetting One-Touch Up Procedure.
One-Touch Down
Press the switch fully and release it. Press again or lift it to stop the window.
One-Touch Up
Lift the switch fully and release it. Press or lift it again to stop the window.
Procedures: Reset one touch windows (auto-up/auto-down), bounce-back
Start the engine.
1. Lift and hold the window switch until you fully close the door window. Continue to hold the switch for a few seconds after you close the window.
2. Release the window switch.
3. Press and hold the window switch until you fully open the window.
4. Release the window switch.
5. Lift and hold the window switch until you fully close the window.
6. Test for correct window operation by carrying out the one-touch down and one-touch up features.
Bounce-Back (If Equipped)
The window stops and reverses if it detects an obstruction.
See the Owners Manual.
Also see Post #3
https://www.broncosportforum.com/forum/threads/auto-window-up-rear-drivers-works-at-times.3831/
But your description of reopening after a full close seems like there may be a hardware issue with the window mechanism
mdwheaton
Matthew
One-Touch Down
One-Touch Up
Yeah, I have the one touch up/down. I'll try this reset procedure, thx!
There are no visible obstructions for either window, and closing it again works.
