Changing Brake Pads - Any tips
nch5013
nch5013
Nicole
Gallipolis, OH
2021 KB Big Bend
That would be worth spending an afternoon of work.
You did not resurface the rotors either, right?
I did not. They looked/felt good and were clean, no warp. The pads weren't as worn when I actually got them off. Apparently just shi++y material.
Like others said, make sure to put it in maintenance mode and don't lose the little plastic caps that cover the caliper slide pins. It was a 40 or 45 hex head... I can't remember exactly.
Do it. You'll be glad you did.
Ford Bronco Sport Changing Brake Pads - Any tips 20220824_164613 Ford Bronco Sport Changing Brake Pads - Any tips 20220824_164604
bjbena
Barry
Escape SEL. EcoSport SES
One last question and I'm good: what made you decide to go with the BRF1954/JX6Z2200D vs what Ford lists for these cars (potentially newer), JX6Z2200E?
nch5013
nch5013
Nicole
Gallipolis, OH
2021 KB Big Bend
I believe they are one in the same?
Ford Bronco Sport Changing Brake Pads - Any tips Screenshot_20220824-200539_Chrom
aroderick
Andrew
The FoMoCo. Couldn't find aftermarket. Rockauto had the best deal on them, ~30 bucks cheaper than Ford. BRF1954.
Did you replace your front pads as well? If so was it the BRF1913’s?
I am assuming these aren’t ceramic. Hoping to avoid the brake dust from the front recall replacements…
nch5013
nch5013
Nicole
Gallipolis, OH
2021 KB Big Bend
I did not. Still haven't, and when I got my new tires, they still looked good - 63k miles.
beaudointl
Ontario, Canada
Be careful with the electric parking brake. There is a lot of information about how to put the parking brake into maintenance mode for other model Fords, but I have seen anything specific to the Bronco Sport yet. I tried the method described in this video and it works for my car.
That procedure is pretty Ford generic and will work on the Sport.
kshaw
Kent
Gaithersburg, MD
You will need a torque wrench, 19mm deep socket, hex sockets, and a tool to compress your calipers. I am fairly certain that the BS will need the tool that rotates the caliper while it compresses. You will need brake grease and silicon grease for the pins.
