- Joined
- Jan 17, 2024
- Threads
- 1
- Messages
- 2
- Reaction score
- 12
- Location
- Yellowknife, NT, Canada
- Vehicle(s)
- 2023 Bronco Sport Big Bend
This post is to share an issue I faced. I'll explain what happened and the corrective action. Hoping it will be helpful to someone in the future.
Vehicle: 2023 Ford Bronco Sport Big Bend with approx 22,000km
Failure Code: P0451 EVAP Emission System Pressure Sensor Performance
Location: Northen Canada, middle of winter, very very cold (-30 degrees)
I noticed a hissing/whining sound from around the LH rear wheel. Engine light came on with P0451 code. The hissing sound was coming form the fuel filler door. A closer look revealed that ice formed around the fuel filler door preventing the EVAP system from building up vacuum pressure.
I left the car in a heated garage overnight to melt the ice and carefully cleaned around the fuel door sealing area. The engine light turned off by itself the next day.
If you have an engine light with P0451, make sure the fuel filler door is sealing properly. If it is leaking, you may be able to hear a hissing sound while the engine is running.
Safe driving !
Safe driving !
