Best tire size for running with Rough Country Lift and rubbing or cutting?
TONKA
Brent
Crowley louisiana
I have a 2021 Big Ben sport and I’m putting a rough country lift and would like to know if anyone has Any suggestions and advice to what is the best size tires to put on it without it rubbing or cutting?
Ford Bronco Sport Best tire size for running with Rough Country Lift and rubbing or cutting? FCED4461-476A-47E1-A8C9-56B16EBD6FE4
MRanderson
Jared
Chino, CA
yuccamanufacturing.com
Bronco Sport Big Bend
Sweet BB looks a lot like ours with the wheels and everything! :D
I have the RC lift on it, running 245/60r18 Falken Wildpeak Trails (not the 3s). They fit great and won’t rub even under articulation. You don’t need the kit with them either.
A note if your doing the RC kit, there have been a lot of problems with it. It will 100% make your ride stiffer. It is also very under built in terms of strength and the sway bar link brackets included will break. I’m sorry to say it is almost not even worth installing unless you absolutely need the clearance.
Ford Bronco Sport Best tire size for running with Rough Country Lift and rubbing or cutting? 2D0D353F-100D-4885-85A7-8E7B207CBB55
Ford Bronco Sport Best tire size for running with Rough Country Lift and rubbing or cutting? 872F2663-DD7A-4169-92CF-3991D3162AD6
Marbec
Mario
You said that you don't need the RC kit and still able to use 245/60R18 without problems? Igot the option 18s and was wondering.
TONKA
TONKA
Brent
Crowley louisiana
Well the told me At rough country that was the biggest that I could put on that factory real son of a gun
jdsnyder13
Jeff
Ohio
I'm running 245/60R18 Falken tires on my Big Bend & do not have a lift kit. I have had zero issues! I was going to get the RC lift kit but saw all the issues & decided to wait & see if any other options come about in the future.
Marbec
Mario
That is awesome to hear. OurGetting ours on in the morning
That is awesome to hear. Our tire guy at S&S Tires told me the same thing. Dude was great, looked up measurement and best fit for our BS BB w option 18s. Getting them babies on in the morning. Thank for the proof!
Marbec
Mario
Ok here you go. This is George BS BB w optional 18s
Before and after pic
**NOTE: NO LIFT KIT REQUIRED FOR THIS REPLACEMENT
Replaced OEM Michelin 225/60R/18
With Falken Wildpeak A/T Trail
245/60R/18. Perfect fit. No rub at all. A little bit of noise, but as you can see, a much meaner stance.
Ford Bronco Sport Best tire size for running with Rough Country Lift and rubbing or cutting? 20210331_114454
Ford Bronco Sport Best tire size for running with Rough Country Lift and rubbing or cutting? 20210331_114444
Ford Bronco Sport Best tire size for running with Rough Country Lift and rubbing or cutting? 20210331_114507
Ford Bronco Sport Best tire size for running with Rough Country Lift and rubbing or cutting? 20210331_114515
Ford Bronco Sport Best tire size for running with Rough Country Lift and rubbing or cutting? 20210331_155731
Ford Bronco Sport Best tire size for running with Rough Country Lift and rubbing or cutting? 20210331_155753
Ford Bronco Sport Best tire size for running with Rough Country Lift and rubbing or cutting? 20210331_155804
Ford Bronco Sport Best tire size for running with Rough Country Lift and rubbing or cutting? 20210331_155803
ElBronc
WA
"30" 235/70r17"
Side profile pic?
4Bronco
Vince
Mississippi
2021 bronco sport
234/70/17 .... That's a 30" tall tire
Ford Bronco Sport Best tire size for running with Rough Country Lift and rubbing or cutting? Screenshot_20210413-085508
