Adding OE fog lights
Bernie
2025 Bronco Sport Big Bend with Black Diamond Off Road
I have a 2025 Bronco Sport big bend with Black diamond offroad package.
It didnt come with fog lights and i would like to add the OE set. I can find the correct headlamp switch and the fog lights from the dealer and a set of brackets and screws.
Should the the wiring be there behind the bumper or is this a separate wiring harness? The dealer doesnt seem to have this answer.
I plan on other upgrades so would prefer not using the upfitter switches at this time.
Thanks
I was told the outfitter switches are not off on by the ignition so battery drain is possible
jonnyb
Jon
As per my previous post, the mounting brackets in that image that your circled would not fit my 2025 badlands (the new mounting pattern is more rectangular). But i can't speak to what you'll find in a big bend bumper.
2025 Badlands Sasquatch
They are switched, so ignition needs to be on for anything connected to operate.
They do have a blue backlight when powered off when you open a door on the same timer as the interior cabin lights. When the ignition is on the switch nameplate lights amber when the switch is placed in the On position.
JPtapt
Thanks
Any progress?
Lawsy13
Danny
Sz1z 15k867 xbb is suppose to be the additional wiring harness to be replaced according to the dealer. Along with the light switch bracket and lights. Unfortunately i have not had the time to work on this due to personal reasons
JPtapt
Thanks. Hope all is good.
