22S73 NHTSA Recall 22V859 Milage Issues
Roxx
Roxanne
Dallas Fort Worth Texas
I had this recall work done about a month ago to my 2022 OBX. They installed a drain tube to the cylinder head and reprogrammed the pcm.
Since the work my gas milage has suffered. All city driving, I went from about 27-28 mpg to now 21-24 mpg.
Has anyone else had a similar experience?
Thanks,
Bronclahoma
Oklahoma
As I understand it this recall was to drain fuel away from a leaking injecter so it doesn't leak on to a hot engine. Sounds like yours is leaking. Have dealer check it.
cprcubed
Patrick
Parker, TX
Not sure how the PCM reflash actually works, but I was under the assumption that in the event of a detected leak the system would go into a mode to reduce fuel pressure/power.. I would also think you would be able to either see/smell any fuel leak. Good idea to have it checked anyway. Cheers!
Thanks,
Keep this information in case you need it.
Customer Satisfaction Program 22N18
This program provides a no-cost, one-time replacement (if needed) of all three high-pressure fuel injectors for 15 years of service or 150,000 miles from the warranty start date of the vehicle, whichever occurs first. This is a one-time repair program.
https://static.nhtsa.gov/odi/tsbs/2023/MC-10233848-0001.pdf
