Roof Rack Info Required
AndyMac204
AndyMac204
Andy
awesome. i’m going to look into these, appreciate the part numbers ??
Benanza
Ben
NJ
So do you know what the difference is between these and Thules that look the same but are twice as much?
Specifically Thule 450R Rapid Crossroad
The 450R is the tower specific for raised rails to be used on the aeroblade. Occasionally they are packaged together with the cross bar, which would cause the price jump. towers for Thule run 150-300 roughly in addition to the cost of the bars 225-275. The aeroblade is more aerodynamic, very noticeable if you are worried about sound.
the evo wingbar bulky design will increase the load capacity, but sacrifices an increase in noise.
AndyMac204
AndyMac204
Andy
nice writeup however i noticed zero noise with these bars. just an fyi ?
Benanza
Ben
NJ
I have a weird hearing disorder, mysophonia, if it wasn't for that I probably wouldn't hear it either. Also depends on location, distance apart, and attacents. Besides, my tires make more noise than the bars do.
AndyMac204
AndyMac204
Andy
haha you got that right - meaty tires are noisy af.
VirtualJMills
California, US
Same here, along with tinnitus and TTTS. I've got my own sound stage in my head. :p
omahafordowner
Keith
Nebraska
Ford Flex
So the evo wingbar says it's load capacity is 220. I am hoping that is per bar? If it is per system, how the hell do you use a roof top tent?
Benanza
Ben
NJ
The load capacity is 220lbs for the pair, while driving. However the raised rails capacity is 150. When your stationary there will be no problem having people in the tent. As the static load is 600lbs for stationary campsite setup.
gdubb757
Greg
Salisbury, MD
Quick Question, and all apologies if this has been asked: when you setup the Evo Wingbar 135 on the Ford Bronco Sport, what width should you set them to? I can't for the life of me find that anywhere.
Benanza
Ben
NJ
It's can vary based on needs but between 24-30 should be fine. I think mine are set at 27.
Cactusjk
Jeff
Woodland Hills, CA
Can you install the K LockNLoad platform directly on the roof rails?
