20" Do fit !
thisgr8ride
kevin
red deer alberta
2021 bronco sport outerbanks
Finally got around to installing the new wheels and tires on the wife's OB today after work .
Before:
Ford Bronco Sport 20" Do fit ! 20211209_132339
After :
Ford Bronco Sport 20" Do fit ! 20220404_183908
20x8 riffino inceptions on 245 / 50 / 20 toyo AT3 No rubbing lock to lock .
No lift No mods just on stock OB.
thisgr8ride
thisgr8ride
kevin
red deer alberta
Thanks... ... was nervous couldn't find any where where 20" would fit but they do and so happy... looks like a bronco now lol !
thisgr8ride
thisgr8ride
kevin
red deer alberta
Thanks, Ride is pretty much the same, only thing I notice really is the steering feels stiffer but might be due to wider tires, very little noise from the tires even at 110km/hr .
AndyMac204
Andy
i don't hate it. looks pretty beefy.
thekingprawn
Dustin
Kingston, Wa
How much sidewall did you lose?
thisgr8ride
thisgr8ride
kevin
red deer alberta
IMO I feel like none, stock was 18" with 225 / 65 these are 245 / 50 so some what proportional . i'll measure old tires vs new tonight .Still lots of side wall if you look close.
Benanza
Ben
NJ
Steering is stiffer because of the short sidewalls which are made of a stiffer rubber to compensate. They will be more responsive on the road. I've also heard it may increase fuel consumption.
Side note: the shorter sidewall will obviously have less grip but if the driver isn't really doing more than dirt/gravel off road, it won't really make too much of a difference for them.
thisgr8ride
thisgr8ride
kevin
red deer alberta
Can't Compare fuel at this time as I haven't put that many miles on them yet, will update when I fuel up.
Also may need to play with the tire pressure a little, may to be to high for this type of tire, but I'll keep an eye on it.
dakman
I'm sorry I like lowered vehicles. I really thought about lowering the BS and everyone told me no way. I could see that dropped 2-3 inches with those 20,s and look bad azz.
thisgr8ride
thisgr8ride
kevin
red deer alberta
It actually raised it, looks lower as the tires now fill the wheel well. Promise you its not lower.
thisgr8ride
thisgr8ride
kevin
red deer alberta
If you look at the chart above, stock was 28.6' diameter , new ones are 29.6". just filled the whole better lol
thisgr8ride
thisgr8ride
kevin
red deer alberta
Just got home to measure.
Stock tires ( my winters but stock size )
Ford Bronco Sport 20" Do fit ! IMG_20220405_190217
New rims and tires :
Ford Bronco Sport 20" Do fit ! IMG_20220405_190212
So almost no loss of sidewall 4" stock and 4"on the 20"
