Weight Capacity of OEM Crossbars?
carlymy
Carly
Ford Bronco Sport Outer Banks 4 x 4
Hey all,
My 2021 BS OB came with the OEM Crossbars: https://accessories.ford.com/products/bronco-sport-2021-on-road-style-cross-bar-kit-1
Does anyone know what the dynamic (moving) and static (not moving) weight capacity for these are?
I know the roof itself has a capacity of 150lb dynamic and 600lb static, but what I don't know is if the OEM crossbars match these ratings. The online description and the warnings on the bars themselves (stating "Maximum Load, See Owner's Manual" ... with the manual stating 150lb dynamic with crossbars) seem to imply it's the same, but I don't want to find out the hard way. I called Ford and Ford Acccessories/Parts, and no one seems to have the answer.
Anyone know?
Thanks a bunch.
Ford Bronco Sport Weight Capacity of OEM Crossbars? IMG_3516
Ford Bronco Sport Weight Capacity of OEM Crossbars? IMG_3513
Ford Bronco Sport Weight Capacity of OEM Crossbars? IMG_3514
sparkerk
Southern California
2010 Ford Escape Limited to Bronco Sport
Hey all,
Anyone know?
Thanks a bunch.
Pretty sure you should go with what the manual says. I believe the weak points will be the roof rails themselves, not the cross bars, since the cross bars will be distributing the weight and the forces of the dynamic load to the roof rails anyway. I don't think you could go wrong with sticking with what the manual says :)
