Almost Done with upgrades - 2021 Bronco Sport Big Bend - Kodiak Brown
bowhunter3714
Missouri
2011 F150
Your Sport looks really good. Are the springs still working out, example, any drivability difference from stock?
Danos
Danos
Dan
Granada Hills, CA
Other than the extra lift, the springs are a little stiffer than stock but handling and drivability are pretty much the same
bowhunter3714
Missouri
2011 F150
I'm glad there working out. I'm planning to get a lift as well. Just trying to decide which one to get. Replacing just the 4 springs is all you did for your complete lift?
Danos
Danos
Dan
Granada Hills, CA
Yes that's all I did. Lifted 1.5 which what I was looking for. Just seemed to me to be a better option than a leveling/lift kit for me. Heard feedback on noises and vibrations with the other options. Good luck
Bamsi
Puerto Rico ??
Nice ride. Someone posted at another thread that needed to re-calibrate front camera and 360° copilot after switching to 245 tires. Any problem with those?
Danos
Danos
Dan
Granada Hills, CA
I did not get those options on my BS. Good luck with any upgrades.
AndyMac204
Andy
best looking nudge bar on the market. your sport is lookin good.
that K&N air filter - any additional turbo noise, just curious. thanks!
AllTerrain
S
Ca
What I have done so far:
BFG KO2 245/65R/17 on Raceline rims
Thule WingBar Evo 135 Black
Ford Ranger Lifts Nudge bar
4 Baja Design XL sport lights
K&N Air filter
Z-Edge Front/rear HD Dash cam
Looking for lift/leveling kit as my next project. any recommendations? Thanks
Ford Bronco Sport Almost Done with upgrades - 2021 Bronco Sport Big Bend - Kodiak Brown 20211007_151806
Ford Bronco Sport Almost Done with upgrades - 2021 Bronco Sport Big Bend - Kodiak Brown 20211007_151729
Ford Bronco Sport Almost Done with upgrades - 2021 Bronco Sport Big Bend - Kodiak Brown 20211007_151712
Excellent!
DISCOLEG
A few questions: Did you install these yourself? Did all four come together, or did you have to buy them individually? How much were they? What's the difference between springs and a spacer kit (other than the obvious physical difference)? Do you know if they put any additional stress/wear-and-tear on the driveline components?
I'm surprised this hasn't come up as an alternative solution to lifting the BS, but to be honest, it doesn't really look like it's lifted (maybe the angle - looks can be deceiving). I looked for them on their website and I think I may have found them. Is this it (part # 51680)?
https://www.hrsprings.com/application/search/results/11/2447/2021/
Seems like can't do this on Badlands and FE
Danos
Danos
Dan
Granada Hills, CA
May I ask how you determined an increase in performance?
Just driving before and after installation.....you can tell the difference (at least I could) especially in Sport mode. Not scientific and not dyno'd but the K&N filter allows the turbo to get more air which is always good. Thanks for your question
Danos
Danos
Dan
Granada Hills, CA
You are correct it seems the H&R spring upgrade is for Base and Big Bend. The other models seem to have more clearance already when adding bigger tires. Thanks
reinhartmike
2022 Bronco Sport Outer Banks
Did you have to remove the bumper for the nudge bar?
Danos
Danos
Dan
Granada Hills, CA
Nope...only thing that was removed was the front license plate holder....
