Air pressure adjustment for larger tire size?
altoblue
Rich
North Brookfield MA
2021 Bronco Sport Big Bend
So I went with a larger tire along with my lift kit. I went from the stock 225/65/17 to 245/65/17. I went with the original tire pressure from the door jamb. Should I be adjusting tire pressure for proper wear with the larger size? I have the ready lift 1.5".
I have the same size tires.
Been running 33psi for over 8k miles, no funny wear or any other issues.
following this link it suggests i lower the pressure to 26psi....
Sounds right to me, especially if the new tire has a higher load rating. Proper inflation pressure ensures (among other things) that the tread remains flat laterally across the contact patch. Too much pressure and the center of the tread will bulge out; too little and it will cave in.
You can confirm proper pressure by carefully watching the wear pattern on the tread over the next few thousand miles. If tread wear is greater in the center then tire pressure is too high. If tread wear is greater on the shoulders then pressure is too low.
altoblue
altoblue
Rich
North Brookfield MA
thats exactly my concern, what im seeing now looks like the pressure is too low as it is. i suspect an alignment issue as only the outer edge cleats of the tires in the rear seem to be wearing ahead of the rest of the tire
You only gave tire sizes in your original post. May I ask the specific brand/model of the OEM and the replacement?
altoblue
altoblue
Rich
North Brookfield MA
original were the continentals pro contact tx i think they were. i changed to goodyear wrangler trail mark
I would suspect alignment as well. If it were under inflation both the inside and outside shoulders would show premature wear. Further, you would see that wear pattern on all the tires, not just the rear tires.
mustangmech
MN
Fords!
Did you get a 4 wheel alignment after the lift? Why did you put “Wranglers” on a Bronco?
I had Goodyear Wranglers on my Dodge Ram 1500 4x4 offroad, they never wore well no matter what, I switched to Cooper tires and the funny wear went away.
If you installed a lift and didn't get it aligned that's where I would start. Also if the outside edges are wearing on your tires there can be a number of causes, alignment, under inflation, high speed cornering (most likely not a BS issue)
AndyMac204
Andy
i’d go with what the recommended psi on the tire itself says. you can adjust from there to your liking.
Young whippersnappers, geez~o~Pete,,
Buy a tread depth guage. Start with OEM pressures. Check it monthly , start a journal.,,,, ok ok. I’ll say it.
If your getting shallow between the middle sipes your running too much air.
If your going shallow in the outer ones your not running enough air or your hanging turns too fast.
Tips:
Most FWD cars benefit with one psi less in the rear if your loads are light.
All AWD cars need equal pressure in all four shoes ?
altoblue
altoblue
Rich
North Brookfield MA
i did get it aligned and i was waiting for someone to ask me that! they were a good price and specs i liked
altoblue
altoblue
Rich
North Brookfield MA
Tips:
all good info, hardly young at 49 though lol but thanks
