My Big Bend disabled 4wd after seconds of climbing on loose ground.
AndyMac204
Andy
What can we Big Bend owners expect in a few inches of snow, leave us stranded when the 4wd disables itself?
never no way. our base has seen deep snow many times so far and zero issues. these sports love the snow.
There is nothing in the manual to suggest too much tire spin can result in a protective/temporary shutdown of the 4wd system. I don't think the tires are your issue.
The PTU has a temp sensor and if it gets hot shuts it down to protect it. Badlands have a cooler lower trims do not. I have read PTU don't have much gear oil like half quart. I wonder if OP PTU is lower on gear oil?
abxponce
abxponce
Bernardo Rosado
Puerto Rico
It is the spinning becaus
Thats a good question.
I would check that fluid level and it needs changing frequently due to low capacity. Its a maintenance thing cause small fluid capacity
abxponce
abxponce
Bernardo Rosado
Puerto Rico
THANKS. Could there be a posibility that there would be an aftermarket PTU cooler?
Don't but if someone came up with one it would sell.
I saw this video guy changing PTU fluid in 2020 Escape:
PTU in the Badlands is water liquid cooled; the PTUs in other trims are air cooled.
This is why I recommended OP take his car to the service department. If it is indeed low then there is a leak or it was not properly filled prior to sale. In either case, it should be covered by warranty. As far as I know, there is nothing in the owner's manual about how to check PTU gear oil level, nor is there anything about its normal capacity or the specification of the correct gear oil.
IMHO, performing maintenance not described in the owner's manual on a car that's still under warranty is not a good idea.
MaxVelocity
Montana
1970 Bronco
I also haven't seen anything. I wonder if it's covered under the transmission service. I didn't see any specifications for that either. I'm sure Ford expects the dealer to perform that.
Yes checking or changing the PTU oil is intended for a properly skilled technician. That is not something Ford is recommending owners do themselves hence not in owners manual.
If you see video in post #54 above the gear oil is supposed to be filled to the top of the fill plug. Should be done by technician with appropriate skills.
MaxVelocity
Montana
1970 Bronco
Correct but I am wondering if there is any fluid change involved for the PTU when they perform scheduled transmission service. It would be interesting to see what the factory service manual says.
