Bronco Sport Engine Appearance Cover 1.5 L Ecoboost
fourthgear
florida
Well, the Engine looks tacky with out it ,IMO As long as there is a demand for the covers , ford will keep stocking them & owners who want them , will keep installing them & of course , some won't .
TomRetired
TomRetired
Thomas
San Antonio, TX
Didn't mean to prolong a controversy just looking for a little help on getting the cover (personal preference). My dealer spotted me the cover, no charge, but had to back order the studs. I would have purchased the cover if I had been properly informed by my dealer or Ford that the cover is no longer part of the build but they didn't know either. Anyway, sorry for the big upheaval and thanks everyone for the advice and insight. Now I am informed!
Kodiakbear
Southern New Hampshire
2021 Bronco Sport Outer Banks
If I ever sell my BSport I’m keeping the engine cover. Too much value to let it go.
I picked up our BS from the dealer today after having the FDM recall done, plus I had them do the first oil change. Before I left the dealer's lot I popped the hood to make sure that my engine cover was still there!
bjbena
Barry
Escape SEL. EcoSport SES
The long white stud in the back is there. You don't need to buy one. There is now a bracket that is on that stud that has two zip tie locations to hold down hoses now that the cover isn't there. You snip those zip ties and gently pry off the bracket (and discard) and the white post/stud is there. You have to buy 3 of the small black studs and the cover but the threaded taped holes or inserts are there with nothing in them so you just screw then in. It's really easy to do. Apparently the Escapes made in the same factory with the same engine are still having them installed. It's really easy to install. If you need the part numbers I'll post them. Does make the engine quieter.
My wife has a 21 Escape SEL with the 1.5 she bought less than a week after mine did NOT come with the cover.
AltoBlue Broncie
2013 Mustang GT, 2022 Bronco Sport
The 2022 I just picked up didn’t have one. I went to the parts department to order and the parts guy said he had one in stock but wouldn’t recommend I buy it. He said Ford didn’t stop putting them on due to cost or supply. They stopped because it was causing the motor to overheat. Is that true?
MaxVelocity
Montana
1970 Bronco
I seriously doubt that explanation. If true I expect Ford would've issued a TSB or recall about the issue.
So a flimsy piece of plastic causes engine to over heat? Wow I gonna go out and pull mine off!!
AltoBlue Broncie
Totally agree it seems like a flimsy excuse. But why make that up versus selling me one of several he had?
On the parts diagram there is a sleeve under the cover. Maybe that’s the piece that causes issues and the cover alone is fine?
