What goes in the accessory ready spot at top of windshield?
Uncle Chris
Christopher
Salisbury, Maryland
2021 Bronco Sport Base, 2008 F-150 5.4 L
What goes in the accessory ready part at the top of the windshield?
Wiring for roof lights , not sure if it is all trim ‘ s , but for sure first edition and badlands .
Ford Bronco Sport What goes in the accessory ready spot at top of windshield? 1A65211F-A393-44AC-B8B9-F7A74BAA00F0
CKV
Vancouver, BC, Canada
Are the wires there already, or is it just a port to run the wires?
Do the roof rails need to be remove to access the wires?
From what I understand the wires are there that go down to under the dash .There is a post on forum that shows this . I have not done roof lights as of yet just preparing . If you look closely on my picture you will see that little section by the window that can be removed , very important this is on the driver side only, I repeat DRIVER SIDE ONLY . HOPE THIS HELPS . JIM. FROM PITTSBURGH
Ford Bronco Sport What goes in the accessory ready spot at top of windshield? 00F3D6BD-42FD-4B20-A920-9C0FD4EA9342
CKV
Thanks Jim. I will take a closer look at mine over the weekend. I found the Ford manual (https://performanceparts.ford.com/download/instructionsheets/IS_M-15200K-CXR.PDF) on running the wiring, and it is a TON of work. Maybe there is an easier way.
Yes I agree , not sure why they say go toward the back , but hey it’s a start good luck. Is that a badlands you are driving ? Looks ?
Ford Bronco Sport What goes in the accessory ready spot at top of windshield? 62223D59-06DD-4899-A745-80F940F787D2
Geelloo90042
Angelo
Los Angeles
2021 Ford Bronco Sport-Badlands
There's an install manual if you get the Ford light bar that shows the purpose of that access panel. A quick glance does not show ia pre wired pack for installing a light bar. Just a way to run wires down the A pillar.
Reactions: Jrl
Robins21
Horse Pasture, Virginia
On our BB it say it on both side of the windshield.
Reactions: Jrl
Winds of Change
Chicagoland
Thats the most asinine process. Really engineers wtf. Just put a harness in there. I wonder how many book hours this takes.
Winds of Change
Chicagoland
0. Beacause a lot of people say screw that lol.
