Thule Evo Wingbars Installed
Benanza
Ben
NJ
Just installed Thule Evo crossbars on my OB. Bronco Baja blanket’s peeking out from the backseat, too.
Ford Bronco Sport Thule Evo Wingbars Installed 2D8AC36B-6049-47F9-98F6-38DB09655CB7
Ford Bronco Sport Thule Evo Wingbars Installed 0A14DAAA-C97D-4FC9-9301-44D3F7E2FB96
Just an FYI...the Thule bars are on backwards. It does seem to look like its right, but the fatter side is supposed to be the leading edge. This will reduce any noise you have experienced so far. Great choice thou!
wsclrk
wsclrk
Wes
Georgia
??‍♂This is my very first vehicle that wasn’t a Ranger or F-150, so I’m a total newb cross bar installation(roof racks/rails in general!). I definitely appreciate you looking out for me, tho. ✌?
wsclrk
wsclrk
Wes
Georgia
I think I had the Thule logos on the passenger as the correct orientation in my mind & completely disregarded that whole step in the instructions but I kinda like it better anyway from a strictly aesthetic aspect-at least until I figure out exactly what I wanna do with the roof & can afford all my camping & trail mod ideas. The whistle is pretty minimal, actually, & not really an issue when bangin it out w/that B&O system.????
Benanza
Ben
NJ
It's a common mistake since it totally looks right... But having this forum to help and learn from each other makes it so much better.
If you have a whistle not just wind noise that is caused by a gap most likely under the bar around the towers. There is a sliding plastic measuring piece and the other you should have cut to place. Sometimes during install the towers push the sliding measurement stick a little, closing that gap could solve the whistle at least.
wsclrk
wsclrk
Wes
Georgia
This forum has been invaluable—I wouldn’t even have these crossbars had I not discovered on here I could put those o/w fairly pointless FordPass points towards them & also that the dealer had left off 2 installed options I’d certainly paid for & I had missed seeing on the sticker. I definitely appreciate your & everyone else here’s tips, no doubt!
wsclrk
wsclrk
Wes
Georgia
Oh, & I already cut the rubber strips & stuck them underneath & that did make a big difference-almost unnoticeable now but I think I have a constant ringing going on in my ears anyway!
wsclrk
wsclrk
Wes
Georgia
Well, I broke down & flipped them the way they’re supposed to be...it’s a lot less pretentious & well, poseurish(& it did eliminate any whistle whatsoever!??) Thanks, again for the head’s up!??
Ford Bronco Sport Thule Evo Wingbars Installed 073E450F-4252-48F5-97EC-1F10F89BDBDB
Benanza
Ben
NJ
The people behind will still see the Thule ? you can be whoever you want to be. Glad the fix helped. At least you know it's not your ears alone ?
adkat
Adam
Long Island, NY
Did you buy them from Ford or from another retailer? Is this the ford kit Part Number: VM1PZ-7855100-C?
Benanza
Ben
NJ
If you don't care that they are brand new you can always find them second hand. It's the Evo wingbar 135. Make sure it comes with raised rail towers.
I found a scratch and dent set that the box was smashed and it has a scratch on the underside of 1 bar. Got it for 1/2 off and I can't even see the scratch
wsclrk
wsclrk
Wes
Georgia
Yeah, & I was able to use my FordPass points towards them, & scored that 15% discount on accessories before the promo was over on New Year’s.
NEFKANO
NEFTALI
El Paso, Texas
neftalicano.com
Great bars... I also bought those crossbars and the Thule 450R legs... Cost more than other options on Amazon, but felt more secure after I tried a generic brand of crossbars. However the rack onto is... an Amazon generic I paid $200 for... Happy with it so far.
Ford Bronco Sport Thule Evo Wingbars Installed IMG_6558
Ford Bronco Sport Thule Evo Wingbars Installed IMG_6560
Ford Bronco Sport Thule Evo Wingbars Installed IMG_6563
Ford Bronco Sport Thule Evo Wingbars Installed IMG_6567
SapphireCat
Catie
Hi!
I've got the same bars coming to put on my Big Bend; did you notice any change in your fuel economy with them on? My last car I had the same bars on and it knocked it down 3-4 MPG, and I was curious if you had experienced anything like that.
Thanks!
