Max Wheel Size without a lift for my Outer Banks?
paddywampus1
Hey guys I want to confirm before going to the shop... Does anyone know if 235/65/18 Falken Wildpeak A/t will without a lift?
Any advice or directions would be much appreciated.
Thanks everyone
Deleted User 772562
Maria
NJ
2021 Bronco Sport Outer Banks, 2021 Ranger Tremor
Thanks everyone
I have an OB and recently upgraded my tires to BFG Trail Terrain T/A 235/60/18 and no lift. No rubbing whatsoever, but when my wheels are fully turned, there’s a small space. I’d say the size of 2 fingers. I, personally, wouldn’t be comfortable going bigger, but I do hear people putting 245’s on without a lift. I think 235 with the aggressive tires will achieve the look you’re going for.
paddywampus1
So are you thinking the extra sidewall (65 instead of 60) will cause rubbing without a lift?
Deleted User 772562
Maria
NJ
I don’t know for sure because I don’t have that size, but mine is pretty close while still being functional. My husband always uses a tire calculator to see the difference between the original size tires vs the potential size. I believe the 65 is going to make the tire an inch taller, meaning 1/2 inch on all sides so that is a little tighter.
https://www.tacomaworld.com/tirecalc
Ford Bronco Sport Max Wheel Size without a lift for my Outer Banks? 04A4F6AE-768E-410F-B00B-0AFCF9922FC8
Ford Bronco Sport Max Wheel Size without a lift for my Outer Banks? 59DE20C7-199E-4A2B-B75E-C53CEF1EEE6D
Ford Bronco Sport Max Wheel Size without a lift for my Outer Banks? 0A14E5EC-470F-4666-9C6D-EF489EA73644
paddywampus1
Thanks a lot for this information
Deleted User 772562
Maria
NJ
Tacoma World.. you a member? I was active on that site when I had my Taco!
No, sorry! My husband uses the tire calculator on it and that was the one he sent me.
Reactions: RRD
Benanza
Ben
NJ
Dan.Bronco
Dan
Seattle
Bronco Sport outer banks
Thank you!! These are the exact ones I want
I highly recommend, no noticeable road noise increase from the stock tires, my mpg went down by about 2mpg but I added a roof basket, lightbar and nudge bar at the same time which are much more likely culprits for my slight lack in fuel efficiency. I have done some light off roading and they have performed well in the PNW. I got them early March so I haven’t experienced a winter with them yet, but I did get caught in a snowstorm on the pass and they didn’t suck like most tires in the snow.
They also look badass, IMO.
wsclrk
Wes
Georgia
Thanks everyone
QUOTE]
As far as biggest wheel size w/o a lift, these are 20” w/30” Toyo Open Country A/T III’s & there’s no rub.
Ford Bronco Sport Max Wheel Size without a lift for my Outer Banks? EB99975B-59F4-42F2-9D56-0738039B6A75
Ford Bronco Sport Max Wheel Size without a lift for my Outer Banks? 39D3D768-8E02-4956-9149-22EEF8469319
