Cleaning Engine Bay.
zjc26138
Zach
Steubenville, Ohio
www.astrobin.com
Did a little mudding today and the engine bay is no longer clean.
How do you go about cleaning the bay and what do you use?
Thanks!
Ford Bronco Sport Cleaning Engine Bay. 7551A20C-1539-414C-9D9A-5D0E0A730CED
Fossil
Ernie
ohio
foam gun with something like simple green followed by a low pressure rinse.
zjc26138
zjc26138
Zach
Steubenville, Ohio
www.astrobin.com
Can anyone recommend a video to watch on how to clean the engine bay?
I found this one, but he doesn't clean the muddy vehicle in it.
zjc26138
zjc26138
Zach
Steubenville, Ohio
www.astrobin.com
ZeroCool
Oh
Very tedious. I could have probably spent another 2 hours on it. I sprayed where I could. But most of the cleaning was using a wet towel.
That was gonna be my guess as I was thinking to myself how could I clean this, as much of it can’t be just soaked with water? You made a very noticeable difference.
zjc26138
zjc26138
Zach
Steubenville, Ohio
www.astrobin.com
I bought some simple green to try next time I wash the vehicle. It has been recommended by several folks.
The manual that is link above doesn’t give a ton of instructions, but does say you can wash it.
Other instructions say to cover alternator and remove the battery. After that you can spray away.
I usually wash the BS once every two weeks. So the next I wash it I will try the simple green out. Unless I go mudding before then.
