Switch controller install
John J
Cooperstown NY
I've been waiting to see this installed. It really looks like it cleans up the engine compartment nicely. Was it pretty easy to install?
ctrabbit25
ctrabbit25
Carlos
Austin, tx
It's pretty easy. I was able to attach to original bolts for the mount and just used L brackets painted black to mount. The hardest part is routing the wire into the interior because of the thickness
John J
Cooperstown NY
Perfect. Looks really clean. Time to order! Thanks for the info. Be safe
davidhluther
Boone, NC
Just installed a 6 gang auxbeam switch controller. Works great, cleans up the engine bay of relays/wires and stops any unnecessary battery drain.
Ford Bronco Sport Switch controller install PXL_20210913_041542474.NIGHT
Ford Bronco Sport Switch controller install PXL_20210913_041413283
How did you connect the ACC? I’m a novice, and the fuses look like a pain to get to. The instructions say “connects the master switch power cable to ACC,” and I’m struggling with how to do that in the engine compartment fuse box.
RogueRodney
Rodney
McKinney, TX
CTRabbit25:
Wanted to thank you for this post, you inspired me to effectively copy you!
I added an Auxbeam 8 Gang Switch (or paid to have it done by Car Toys in McKinney).
Ford Bronco Sport Switch controller install 1684681153346
Ford Bronco Sport Switch controller install 1684681166556
With MicTuning C3 16 Pod Rock Light System:
Ford Bronco Sport Switch controller install 1684681196916
Happy Trails All, and thanks for the suggestions!
RR
