AndyMac204
Andy
swamis
Allie
2021 Bronco Sport Big Bend
looks great! i've been eyeing the bumper lightbar from rough country myself. where do you have the switch?
ctrabbit25
ctrabbit25
Carlos
Austin, tx
The switch is under under the other light switches on the left driver side. I went through the wire access grommet behind the battery to get the wires inside the cabin
ctrabbit25
ctrabbit25
Carlos
Austin, tx
I added threded inserts to the bottom of the bumper and used bolts to attach it. It also has holes allowing access to the original bolts under attaching the bumper to the car. So the the bumper can be removed without removing the skid plate
christopheru
The Great White North
Interesting and thanks for the reply.
Yousef
Sealy,tx
2021 Bronco Sport Badlands, 2018 F-350, 1960 T-Bir
I just got my bar/ lights. Do you have to remove bumper for install? How is routing, light switch located? Thanks for info.
ctrabbit25
ctrabbit25
Carlos
Austin, tx
The bumper has to be removed and lighting is routed before you put the bumper back on. The switch gets routed through the firewall access point behind the battery to inside
Yousef
Sealy,tx
10-4 I'm considering getting the R/C switch cluster for the various components vs having multiple switches drill points.
