What fuse for High beams?
Zkrueger24
Illinois
2021 bronco sport
I am trying to run a fuse tap into the high beams so that I can have the Rough Country light bar and have it turn on automatically when my high beams turn on. But I am having trouble decided which fuse to tap. Any suggestions?!?!
nd2432
Washington, DC
Bronco Sport Badlands
Don't know the answer, but as a fair warning most states don't allow extra lighting to be turned on during highway use. If you know you'll never be turning your highbeams on when on a highway/roadway then you should be fine.
Fossil
Ernie
ohio
probably not a fuse but a circuit breaker
was going to suggest the same thing. A direct toggle switch might be a safer approach. Granted someone in ruralville with limited highway driving, it may not be a big deal...but knowing local codes is important.
