Anyone know if there is a remote window rolldown feature?
FM415
Francis
Bay Area, CA
Was interested in this as I had the ability to rolldown windows from my remote on my previous vehicle.
This is also a selectable preference through the vehicle options so if it doesn't work, check the "Windows" section and make sure it's turned on.
brockdog12
NTX
Is this on all BS models?
FM415
FM415
Francis
Bay Area, CA
Thanks for the info everyone!
FM415
FM415
Francis
Bay Area, CA
I am not seeing this option, by any chance do you know if its available on the Big Bend model? Thanks in advance!
Central Jersey
Mordechai
NJ
Bronco sport big Bend
Not on my big bend I checked.
maybe this only works if your key fob has a remote starter ? (mine does not have remote start only thru the ford pass app )
kman779
I believe the feature is only for those of us with factory remote start via the key fob. That would be Outer Banks and higher trims if I recall correctly.
Might be my fault for assuming, but I assumed anyone with the remote fob could do it. It's on page 88 of the user guide.
GLOBAL OPENING AND
CLOSING (IF EQUIPPED)
You can use the remote control to open
the windows with the ignition off.
Note: You can enable or disable this feature
in the information display or see an
authorized dealer. See General
Information (page 98).
Note: To operate this feature, accessory
delay must not be active.
Opening the Windows
You can only open the windows for a short
time after you unlock your vehicle with the
remote control. After you unlock your
vehicle, press and hold the remote control
unlock button to open the windows.
Release the button once movement starts.
Press the lock or unlock button to stop
movement.
Closing the Windows
To close the windows, press and hold the
remote control lock button. Release the
button once movement starts. Press the
lock or unlock button to stop movement.
WARNING: When closing the
power windows, verify they are free of
obstruction and make sure that children
and pets are not in the proximity of the
window openings.
Ford Bronco Sport Anyone know if there is a remote window rolldown feature? IMG_20210603_170130702
Ford Bronco Sport Anyone know if there is a remote window rolldown feature? IMG_20210603_170120715
FM415
FM415
Francis
Bay Area, CA
GLOBAL OPENING AND
Opening the Windows
movement.
Closing the Windows
window openings.
I think it’s only available on the higher models. Thanks for the info though!
