How to turn off auto heated seats
gqtrebor
Edmonton AB Canada
I keep going into the Auto heated seats and turning it off but every time I do a remote command start on the Ford app or with the key fob the heated seats keep coming back on and I don’t want to come on. Is there a setting or somewhere that I can just shut them off completely?
DWG
New Jersey
If your car did not come with an owners manual book Luckily Ford still has a pdf version of the owners manual for 2025. Link: 2025.
Instructions for remote start settings are o page 104 of the manual.
RC Turner
Southern Minnesota
The manual is very little help with the "auto" heated seats. It really only makes a minor reference to the fact that they are even there. I think that you simply select the icon on the center display to deselect the auto function.
You've probably already seen this from the owners manual, if not here is what the manual says.
The heated seat settings are in the remote start menu.
Heated Seats (If Equipped) - Switching the Heated Seats On and Off
Ford Bronco Sport How to turn off auto heated seats {filename}
The vehicle must be running to use this feature.
Press the heated seat symbol to cycle through the various heat settings and off. The more indicators that display, the warmer the temperature of the seat.
Note: The heated seats may remain on after you remote start your vehicle, based on your remote start settings. The heated seats may also turn on when you start your vehicle if they were on when you switched your vehicle off.
Note: Select Auto to heat your seat based on your climate control settings, humidity and air temperature.
2025 Bronco Sport Owner's Manual
Remote Start (If Equipped) - Remote Start Settings
  1. From the settings menu, press Vehicle.
  1. Press Remote Start Setup.
You can adjust the following in the remote start settings menu:
  • Enable or disable remote start.
  • Climate control settings.
  • Heated seat settings.
  • Heated steering wheel settings.
  • Remote start duration.
gqtrebor
gqtrebor
Edmonton AB Canada
  2. Press Remote Start Setup.
Thank you, thats what i was looking for....
Stircrazy
BC, Canada
they will stop on their own in the summer. it is a temp based thing. same with the ac and the heated stering wheel, and the rear defrost. I think I saw options in the settings menu under remots start though,maybe in there
Iamcanadian
Jason
Ontario Canada
2025 Big Bend Black Diamond Off Road
The owners manual is in the Ford app and it's built right in the infotainment system
