Rattling Noise on uneven pavement Solved!!
Iceman3108
Martin
Argentina
Thank you so much for the Feedback received. I had taken it to the dealer and the problem was the front wiper system that was touching with the engine frame. It seems that it was bent when the windshield was replaced!!
Hi Everybody, there is an annoying rattling noise coming from the front driver side mostly on uneven roads. There is a video attached. It is not a suspension issue. Any comments will be much appreciated. I'm talking it to the dealer tomorrow.
Shadow Bronc
ELF
Washington
Yeah, I differently hear that. Sounds like something is loose under the hood. Do you off-road alot? Any small incidents you can remember? Just a question, did you just have your oil changed? It's snds like they didn't tighten the plastic part of the skid pad, front is steel but the rear part of it is plastic, and it's loose, it would rub even on even smooth roads.
Iceman3108
Martin
Argentina
Thanks for your reply! I did made a long travel with off roads. After that, I had take ot to the dealer for a service and windshield replacement. Since then, I had noticed that noise....now is more frequently and louder.
thomasm23
Los Angeles Metro
Have you recently had your battery replaced?
Check the air box and plastic snorkel for vibration. A missing rubber grommet or incorrect plastic rivet may be the cause.
Iceman3108
Martin
Argentina
Hi Thomas, I did not. I will check it out! Thanks for the info!
