AWD Fault C0690
ttomecki
TOM
POLAND
BRONCO SPORT
Hi , can anyone help?
On display I have wrench and AWD Fault, in forscan have C0690:7F-AF
Ford Bronco Sport AWD Fault C0690 20250911_122051
My Badlands 4WD module had a fault last year, it also trigged a number of other codes.
Vehicle was at the dealer almost 2 weeks.
Diagnosis: 4WD module not communicating with other systems, dealer replaced the module.
In my case the module was not covered under warranty as I was just over the 3yr/36000 bumper to bumper warranty and also was not covered by the 5yr/60000 powertrain warranty because its considered an electrical part.
In the end Ford did do a goodwill gesture, otherwise the repair bill would have been close to $1000 dollars.
When I was doing my own research there were a number of complaints on the NHTSA site with various model (Escape, Corsair, Edge, Explorer etc) Ford 4WD/AWD systems.
Typically the 4WD/AWD module, actuator motor or speed sensor was the cause of the problem.
Another person on this board had the 4WD fault and it was a wiring issue caused by vermin.
ttomecki
TOM
POLAND
BRONCO SPORT
Yes, thanks but what first? Module? Which motors ? In badlands are two, left and right? What's parts number off new module?
BroncoArea51
Jeff
Racine Wisconsin
2010 Mercedes C300, 17CorvetteGS 1964 Corvette cou
2022 Ford bronco sport 57995 miles.. i get off the interstate, and i'm in a subdivision, and the wrench comes on. Avoidance crash, 4 wheel drive in op. Hill assist and op cruising op. Adaptive cruise control in op
My first thought is, I'm this close to 60000 miles, and this is what happens..
I assume is a computer that controls the transmission. And based off of this threat, I assumed that it would not be covered under the drivetrain.
I got to my destination less than 5 minutes later. I shut the car off restarted the car and about 1100 miles later. So far, nothing.
I got the new AMG battery installed under warranty, and what I can figure is sometimes you'll just get a low voltage, creating that wrench. It shifts fine and drives fine, but it sure doesn't instill any confidence.
Still have a emissions light for the vapor control valve.
You have other posts from April with possible RDU problems, was that resolved or is this a continuation from April.
You don't want to just throw parts at the problem, you need more information like an actual diagnosis otherwise its just a guess of what the cause is.
If the 4WD module is the problem the replacement module will need to be programmed to the RDU.
Module P/N M1PZ-7P238-C
ttomecki
TOM
POLAND
BRONCO SPORT
Yes, that's a continuation, the problem persists. Is the module number the new 2025 module for the Badlands version?
The diagnosis is either a faulty module or a damaged left or right actuator.
