Washer Fluid Leak From Camera Nozzle
Chief of the Boat
Terry
Bremerton Washington
Bronco Sport & 2019 Ranger Lariat FX4
Noticed washer fluid leaking from the front camera nozzle of our 21 Badlands. Bought it new and have driven it 65,000 trouble free miles. We park it nose down and the nozzle may be a little worn so it siphons the tank empty. No check valve from the factory, there will be one on Friday.
Sandman
Scott
MI
21 Ford Bronco Sport
Hah on my 21 First Edition I started having same problem leaking in my garage when I fill it. The next day blue puddle and low fluid warning light on.
crockermt
Monment, CO
Had same issue on my 2021 Badlands. Had 70,000+ miles. Was planning to get it fixed but the vehicle got totaled before I had a chance. Now driving a 2025 Badlands
warpig
Louisiana
Both front and back were leaking. I installed this on the front by the tank. Plugged back.
check
@Chief of the Boat … Did you install the check valve close to the tank or close to the front camera?
I’ve seen owners do either option and both seem to work
Ford Bronco Sport Washer Fluid Leak From Camera Nozzle IMG_1593
Here you go.
Ford Bronco Sport Washer Fluid Leak From Camera Nozzle 20251017_084309
Professional install! Thanks for the clear pic.
after using the front camera washer have you noticed any residual flow or dripping out of the front camera washer until the fluid in the length of tubing (on the camera side) past the check valve drains out?
