Problem with TPMS sensor
Gapbriel
Gabriel
Argentina
Hey guys, recently, there appeared an error, and I wanna know if i need to reset all of them or just died the sensor ... if i need to reset how i do it myself? i just found some videos on youtube doing 3 times off/on and pushing the break ... but i don't it
thanks for read
Ford Bronco Sport Problem with TPMS sensor 1740183110000-3
Humper
Mick
Oklahoma
Not unless the battery is gone in the sensor, I believe the sensors reset themselves after driving for a while, seems a bit early for batteries to start dying though.
Bigband
2024 Bronco Sport
The tool that you have to have to reset the sensor is extremely cheap. $10-15. Follow the instructions on YouTube. If it doesn't reset, take it in to the dealership.
Gapbriel
Gapbriel
Gabriel
Argentina
Thanks guys I will buy it and do again all the stuff
Dannyp56
Danny
Payson, AZ
2024 Ford Bronco Sport
When I bought my 2024 BSOB I noticed the tire pressure was over 40 psi. Took it to a Ford dealership and they let 15 psi out. They said something about overfilling them for shipping and the dealer was supposed to let the excess air out
Gapbriel
Gapbriel
Gabriel
Argentina
You should be able to have the TPMS sensor checked at most any retail tire shop which would be much quicker than scheduling a service appointment with Ford.
With a TPMS service tool the tire shop can tell you the sensors status, battery voltage, signal output, etc. They can also reset the sensor if needed.
There have been a few other posts on this board where some others had the same TPMS problem, turned out the TPMS sensor was bad and had to be replaced.
If your Sport is still under warranty the TPMS should be covered.
Gapbriel
Gapbriel
Gabriel
Argentina
It’s under warranty so I will go to the dealership … I try reset but I’m 100% that it’s dead ?
