Front Suspension Noise
zyglyrox
Cory
Cleveland
BaseSquatch & BB Sport
Hey BSF, Cory here with some questions regarding our lifted BB. we used the HRG kit, it’s been lovely and the look and extra ground clearance is great.
We’re now having a clunk in the front end, I was thinking end links because of all the people with subpar quality links. but has anyone blown apart a top hat? or maybe something loosened in the front I should double check?
i wanted to pick yalls brains before i go tear this thing apart in the freezing weather.
Cursed Bronco
Dakota
Indianapolis, IN
I have the very original version of the rough country lift dealer installed and this happens to me once or twice a year. It is always the sway-bar end links coming loose and needing to be tightened up. Not sure if it is the same with HRG, but sounds similar although mine sounds a bit lower in pitch when it happens. Sort of like a thunk
zyglyrox
zyglyrox
Cory
Cleveland
Thanks man, I’ve seen all the hubbub about the end links, that was my first guess but KNOWING my luck it’ll be something nobody has ever seen before ?
Robink
Robin
Utah
Ford Bronco sport
Mine thunks as well. I finally gave up taking it in for them to check it. As long as the noise stays the same they tell me mine is OK. Mine is a BB as well.
zyglyrox
zyglyrox
Cory
Cleveland
can you guys replicate the noise at slow speed, but quick left and right steering back and forth?
Cursed Bronco
Dakota
Indianapolis, IN
I can not duplicate the sound simply turning the wheel. Only on bumps when the momentum is transferred via the swaybar. I did have a similar issue before hearing a similar noise upon turning the wheels, it was a loose strut tower nut allowing for the strut to move slightly at full lock, or quick turning movements.
zyglyrox
zyglyrox
Cory
Cleveland
tried it while parked and it won’t make any noise. soon as i start moving and compressing the suspension it acts up…
i ended up taking a look and it looks like the “trusted shop” i said i took it to never greased my fittings… over 25k now ?
jhnvan
James
bronco sport
End links for sure. Had the same thing on mine. HRG switched to different ones after a while for more reliable ones.
Greg
www.instagram.com
2024 Bronco Sport Badlands
Sorry to bump an old thread, but did greasing the fittings help the sound go away? Was it something else?
I recently had HRG 1.5” installed on my BL, and I too have similar thunk from front suspension area. Shop confirmed everything is snug and operational, but it still makes the noise.
rzims
Rich
grass valley, ca
2022 bronco sport
I installed new end links from HRG hoping that would solve the problem. Nope....even when parked and turning the wheel i get the squeak
