Powertrain malfunction/reduced power
Voodoo
drew
24 Bronco Sport
Went out to town earlier and came home, then the wife started out and said there was a wrench showing up in the dash and had that message in the app. Went out put it in reverse then forward in the driveway and it went off. Then I drove it around the neighborhood once and everything felt the same and the light still hasn't come back. Software glitch maybe?
Chiefthepup
Colt
Washington
Mine ended up being a loose ground at the fender from me being an idiot. Lol I’m not saying that’s for sure your situation but if it does it again randomly than goes away like that that’s what mine did.
Many who have reported random dash lights have traced the issue to a bad battery. A bad battery connection, such as @Chiefthepup reported, is similar to a bad battery since it can interrupt the flow of power to the system.
Voodoo
Voodoo
drew
24 Bronco Sport
I did get it lifted recently and oddly enough the wrench popped up after I washed it and used a car blower to dry it so I wonder if something is exposed somewhere.
Chiefthepup
Colt
Washington
Yeah maybe the ground point that’s in the spot right next to where the shocks or whatever bolt into got knocked slightly loose when they installed? Mine was loose and I thought it was secure so I don’t think it takes much for it to start acting weird.
Voodoo
Voodoo
drew
24 Bronco Sport
Well the light is back and won't go away this time ? good thing we already scheduled an appointment for Thursday
Chiefthepup
Colt
Washington
Dang it! Keep us updated I’m interested on what it could be!
Voodoo
Voodoo
drew
24 Bronco Sport
Tech basically blew it off said it could be a sensor or when the battery loses a volt or something it could set it off. It was off this morning and hasn't came back on. He said if it goes into limp mode then bring it on lol.
charlier
Charlie
NC
Had the same issue Sunday on brand new 500 miles 2025 BS Badlands. What was scary was the gear shifter moving itself
Ford Bronco Sport Powertrain malfunction/reduced power IMG_4073
Ford Bronco Sport Powertrain malfunction/reduced power IMG_4072
. So for example, I put the car in R and the shifter moved back to P. Very strange. Turned the car off 3x’s and the error no longer appeared. The wrench in the display also no longer appeared. The service alert light stayed lit. Car has been at dealer since Monday. The assigned master tech is consulting with manufacturer.
Voodoo
Voodoo
drew
24 Bronco Sport
Ford is having alot of issues going on it seems. I still have some recent recalls on my 22 mustang that needs attention and I just had to get the water pump replaced in my Bronco Sport due to a coolant leak....Luckily I haven't had anymore issues with the light again tho.
