- First Name
- David
- Joined
- Jun 19, 2023
- Threads
- 19
- Messages
- 468
- Reaction score
- 607
- Location
- New Jersey
- Vehicle(s)
- 2019 Edge, 2024 Bronco Sport Badlands
As I think most every one here knows. This is a known unfortunate issue with the 8F35 transmission. There are several TSB's for my 19 Edge which basically tell the Dealer to flash the PCM with the latest software version. It has not helped and the Dealer now just says it is normal. The shudder/buck for me only happens when initially driving from a cold start at just below 20 mph. Once I am out of the neighborhood and can get up to 45 - 50 mph the shudder/buck goes away and does not come back until the car is cold again. It does not happen every time I drive from a cold start. It seems to be outside temperature sensitive happening primarily in warmer weather. It happens to a lesser degree with my 20 Escape and surprisingly I had it happen a couple of times on really hot days with my 24 BS which only has about 1800 miles on it. It happening with my brand new BS was very disappointing in that obviously Ford does not have a fix. It also makes me think that some of these fixes that others are coming up with may only be temporary or would not apply in my case (especially on a brand new car).
On the Edge forum some are posting that replacing the EGR valve fixed their issue. Also as I mentioned in my case the shudder/buck is only when the vehicles are cold in warmer temperatures and only at speeds below 25 mph so some of the shudder/bucking others have experienced sounds different than what I experience. As long as my symptoms don't change I am resigned to consider the issue a characteristic of the transmission.
thomas23, please keep us posted on how the lubegard is holding up.
