Just installed the least necessary and least cost-effective mod to date. But I love it.
Ford Bronco Sport What did you do TO your Bronco Sport today? IMG_5012
Are the stock tire inflator stems that bad?
They didn’t have like horses on them.
Ha to me! I did not notice that at first; I had to go back to the pic and re-examine. Now I see it!
Purty blue; I like.
Major Kong
Major
Right Here Right Now
Bronco Sport aka "Spark Plug"
embarrassingly low mileage
first oil change
intel oil monitor says 28% remaining
1 year period was up mileage or not
learned a few things
yeah it had the weird off-green cast to the used oil color
removed cheap runty factory oil filter
look me in the eye and say you're not ashamed ford
:mad:
upside
belly tray removed
access gained to lower motor compartment frame work
steel frame components wetted down with wool wax
reset intel oil life monitor
fresh start with 742 miles on the odometer
Deleted member 6350
Installed a J&L OSC 3.0 Oil Separator
Quick an Easy Installation, I would also advise that you use Blue Loctite
on the Nut from the Alternator Bracket.
Ford Bronco Sport What did you do TO your Bronco Sport today? 6BF64CAE-25A6-4AA0-BE74-9EC3BFA8D37D
Ford Bronco Sport What did you do TO your Bronco Sport today? 315A6344-1EA3-4053-B993-14E4B295810B
coopny
NY
2023 BS BL
A couple of days ago I ran a wire for my Uniden R7 radar detector (mounted to the mirror stem via a Blendmount - highly recommended) through the headliner, down the passenger A pillar to aux power. I also took the opportunity to run a front/rear dashcam combo (Viofo A129 Pro Duo - 4K in the front, 1080P in the back). The install is clean with the windshield and such, although I have it wired to a DC plug splitter instead of fuses (which may be a later project).
cprcubed
Parker, TX
Oil changed at my dealership and also having the rearmost quarter glass replaced (something struck it unbeknownst to me and shattered it :frown:). $915!!! ($375 for glass, $180 for panel that has to be removed and can't be reused).
Scott_Anderson_
Scott
Arkansas
2021 Badlands Cactus Gray
Impressive! If you ever run out of electrical mods to do on your rig, give me a call. Wish I had the acumen for it.
jhnvan
James
bronco sport
Installed all my skid plates and the rear suspension lift (didn't have time for the fronts today, will finish tomorrow). Makes me feel a lot better about going offroading now!! Unfortunately the new plastic oil pans don't have the oil drain off at the same place it seems.
Ford Bronco Sport What did you do TO your Bronco Sport today? 20230412_154750
jhnvan
James
bronco sport
Finished installing the lift kit and had an alignment done. Ford didn't want to provide the alignment specs saying it was proprietary info and i should have the bs towed to the dealership.... i found the specs i needed a different way but it caused some delays.
Ford is really dropping the ball here by keeping the info "secret". Sometimes towing isn't an option and I honestly didn't want to wait 1 week to get an appointment for this to be done and meanwhile wearing out my brand new tires.
Ford Bronco Sport What did you do TO your Bronco Sport today? 20230413_160401
