Got rear ended and have a question about the bumper…
kapk22
2021 Bronco Sport, 2021 Jeep Wrangler
We have a 2021 Big Bend without the tow package and recently got rear ended. There is minimal damage, but the cover needs replaced. We would really like to just have the cover replaced with the oem style that has the cutout for the hitch.
From what I can see, there are several different cover options. Ours has the little round plugs around it for the sensors (at least I am thinking that’s what they are for).
has anyone done this kind of bumper cover swap to get the hitch? I’m thinking it will make it easier for the shops to install the hitch when we end up getting it and it will look oem.
Ford Bronco Sport Got rear ended and have a question about the bumper… 6047FBCE-FA30-49C9-80ED-868FAB6861EC
Ford Bronco Sport Got rear ended and have a question about the bumper… C233BE2F-C3FF-4DA1-91CC-2BC11FB2B241
Ford Bronco Sport Got rear ended and have a question about the bumper… 328DECFB-5533-4340-ABF2-12A7985B8A7F
That's unfortunate, hopefully nobody was injured.
Buying used can save you VS. new
Depending on the damage, there are a number of parts under the bumper cover that may also need to be replaced.
Looking here:
https://parts.ford.com/webapp/wcs/stores/servlet/SearchDisplay?year=&make=&model=&searchTerm=rear+bumper+cover&storeId=1405&catalogId=251&langId=-1&searchType=partnumber&nextURL=https://parts.ford.com/shop/en/us&storeId=1405&catalogId=251&langId=-1&mode=add&errorURL=https://parts.ford.com/shop/en/us&ymmOnly=true&ymm_id=__#facet:&productBeginIndex:0&orderBy:&pageView:&minPrice:&maxPrice:&pageSize:&
The displayed bumper covers say the cutout for the hitch must be drilled and cut as required.
kapk22
Looking here:
No one was hurt. It was at very low speed, just exiting a parking lot. It looks like the plastic is just wrinkled a little and the plate light housing is cracked.
I’m fairly confident nothing else is damaged behind the skirting. I was thinking about just asking Ford to get the cover that has the cutout and the hitch. Then just have their service department remove the damaged cover and install the hitch and cover.
Fordone Badlands
Ontario
22 Bronco Sport
Makes sense to have the hitch installed at the same time the bumper is off to be replaced. Don't forget the wiring harness.
