18 inch wheels
renz A.
renz
canada
bronco sport
I just need some help. I’m planning to buy a/t tires for my outer banks. Im trying to choose between 235/60/18 and 245/65r18. Can any one help me which one will perfectly fit without any lifts? Thank you.
GulfCoastBronco
Topher
Corpus
245/65/18 will limit your choices. Not all manufacturers will have that dimension, from the last time I looked. I’ve seen a handful of peeps post 235/60/18 and been satisfied. It is a 29” tire. I went with 235/65/18 after chatting with the folks at @Discount Tire went with Toyo Open Country AT3 and have really enjoyed them. I believe those will still fit with no lift and I believe I have seen one on here with those and no lift.
Ford Bronco Sport 18 inch wheels 07B1E64F-02B6-4954-A9A2-07883D3E737E
renz A.
renz
canada
bronco sport
That’s great. Hiw w
that is great. Did you had any issues with your 235/65? Scrubbing etc? Im planning to get a nitto nomad grappler. Really nice tires on your bronco. We have the same color ?
GulfCoastBronco
Topher
Corpus
That’s great. Hiw w
No issues but I do have a lift. You can see still plenty of room.
Tigger
Tigger
Illinois
You will have no issues with the 235 or 245 18” that you mentioned. Just note that a lift would not affect the tires that fit.
You currently have 225 so an increase to 235 is a nice balance for A/T tires and not sacrificing mileage or noise. 245 are better looking (to most people) but come with slightly worse noise and mileage.
Do a search in these threads for 235 18 and 245 18. Many threads, many opinions but I really liked my Toyo at 235 18’s.
jhnvan
James
bronco sport
I'm currently running 245/60/18 without a lift and there is no rub at all. Limited in tire choices though. The 65 profile might start to rub though
renz A.
renz
canada
bronco sport
Thank you for the info. I might consider the 245/60s. I don’t go off roading. Mostly on highways. Did your 245s made a change on the mileage?
jhnvan
James
bronco sport
I can't comment on that as I switched the wheels before I left the lot. But I'm getting around 10L/100km before I put my roof tent on.
renz A.
renz
canada
bronco sport
Thank you. I might go for the 245/60s. Luckily i just checked and they have that size on the tires that i like. A nitto nomad grappler. Any thoughts about those tires?
jhnvan
James
bronco sport
I'm personally going to be getting Pirelli Scorpion AT+ tires on 17 inch motegi wheels as that's what's available locally. I've never had Nitto tires.
