Bluebaru
Several people have mentioned this, in the recent past, including me, but now that it shows up on their site I thought I'd post a link. You may notice several differences, from any other lift kit. Some of the differences are, a front subframe drop, brake line relocation brackets, rear shock extensions and a 6-7 hour installation time.
https://www.hrgoffroad.com/2-5-inch-63-5mm-ultimate-lift-kit-for-2021-23-ford-bronco-sport/
Complete kit includes:
  • 4 lift spacers (2 front and 2 rear)
  • TTX sway bar end links
  • Rear shock extensions
  • Trailing arm spacers
  • Brake line spacers
  • Brake line brackets
  • Front and rear subframe spacers
  • Camber Bolts
  • All necessary hardware
  • Detailed illustrated instructions.
Kit includes: two 2.5 inch (63.5mm) and two 1.5 inch (38mm) thick powder coated steel rear suspension lift spacers that will lift your vehicle 2.5 inches overall. You will also notice improved approach and depart angles, as well as improved break-over angles.
This kit increases ground clearance by 2.5 inches.
Proprietary design- NO FRONT STRUT RATTLE. Application specific sway bar end links
Fits 2021-2023 Ford Bronco Sport First Edition and Badlands edition. Our kits are powder coated for a durable, attractive finish and use new grade 10.9 hardware.
Tire size suggestions:
245/70/16
245/65/17
245/60/18
Approximate installation time 6-7 hours
Ford Bronco Sport HRG 2.5" Lift Kit - official pics & details / specs 1668873168991
Victorsen
Victor
Maryland
I want this now!
  • Camber Bolts
245/70/16
245/65/17
245/60/18
Has
  • Camber Bolts
245/70/16
245/65/17
245/60/18
has anyone done this lift it is expensive and wondering if it effects vehicle dynamics 2.5 vs the 1.5 inch spacer lift
RiotfunK
Mass
22 Bronco Badlands
Any pics of it actually installed
Outback Texan
MIke
San Antonio, TX
...and their web site clearly states... FOR OFF-ROAD USE ONLY!
DatWayMon
Dennis
Southern California
Bronco Sport Badlands
I'm curious about this as well. It seems that it's not only a lift kit but to some degree a leveling kit, and if so what percentage of the positive rake will be removed.
I'm no expert but this seems like typical CYA stuff and by no means are they saying you can't drive your BS as you normally would. If people had to actually trailer their BS from home to Off-Road location HRG wouldn't be able to sell a single unit.
