I popped mine off this morning. The center screw (M5-.8) is pretty deep under the cover. looks like if you did a 1 inch ball that has the 1/4-20 tapped hole, you could just drill a hole in the cover and add a black fender washer on the outside and a 1/4-20 bolt and fender washer from the inside. The 3 inch B clamp puts my GPS right above the center screen. I might see what I can do to make a part that mounts directly to the center mount to make it more rigid.
I didn't tear mine up yet, but I am undecided what to do. After a year of using the factory Nav, I'm a little over it and ready to go back to my Garmin GPS. I don't want to pay for cel data so CarPlay isn't an option for me.
This is my previous mount. The GPS has this dock and I just fixed the mount to the dash with that 3M tape. The dock will pop onto any ball mount like that, I think it is 17mm. Very solid, but it did require a lot of wiring to get the wire into the dash. The Garmin uses a custom cable that goes from a 12v to a mini USB. It looks like there is a lot of space back there to run a cable down to the fuse panel and I can put a 12v outlet someplace. I have to locate a different ball adapter or just go ahead and stick this one to the Bronco dash. I was thinking the same as you, sandwich it to the cover.
Ford Bronco Sport What did you do TO your Bronco Sport today? IMG_20221030_122354245
Ford Bronco Sport What did you do TO your Bronco Sport today? IMG_20221030_122401434
I would get a 1” to 17mm ball adapter. That’s my plan.
Ford Bronco Sport What did you do TO your Bronco Sport today? 6447D052-1A6B-474B-B8DD-A333740DDBD9
Discount Tire
Arizona, USA
discountti.re
All Things FORD
Went to Discount Tire and ordered 5 of the Falken AT3W today, they gave me credit for my factory 235 Pirellis so that was nice. Can’t wait to get them installed but that won’t be until next Saturday as I leave on a work trip tomorrow. Also ordered several accessories for the inside and out.
Thank you for your business, Allen! Have a safe trip!
UncleRenty
Ian
Orlando, FL
2022 BS Badlands, 2021 Tesla MYLR
What kind of credit did you receive? I am about to do the same. I am also curious if they will do the install for my spacer kit.
TravisPNW
Travis
Des Moines, Washington
OEM mudflaps and floor mats installed.
Ford Bronco Sport What did you do TO your Bronco Sport today? MatsFlaps
I think what I like most about this vehicle is the lack of carpeting.
She goes into the shop tomorrow for 4 days for full frontal PPF along with a ceramic coat.
Kraken23
Allen
St. Louis, Missouri
2022 BS BL
So that’s a loaded question and I’m sure my answer might open a can of worms and opinions.
I’m sure that the amount of credit, if any, is subject to many factors (location, type of tire, # of miles on tires, etc). Now with that said I feel like I should have tried to get more for mine since they were basically brand new Pirellis with only 500 miles on them. In the end they gave me 30 for each including the spare so $150 total plus since they are not being disposed of they didn’t charge me the disposal fee which I know isn’t much. For me it meant that I got something for them and I didn’t have to try and sell them myself.
The local Discount Tire store that put on my spare would not take my Pirelli spare. They said it had no value. I was ok with it as they gave me a great deal considering I only bought one tire. So…….I’ve got a spare for my spare now!
Kraken23
Allen
St. Louis, Missouri
2022 BS BL
Yeah to be honest I was surprised that they did give me what they did for them since I’ve read it’s hit or miss. In the end they’ve earned a customer who will comeback the next time I need tires. Or maybe when I find the right sort of wheels for the ride.
UncleRenty
Ian
Orlando, FL
That is kind of what I heard from others. I have like 700 miles on mine and I have heard some in the range of $30-50/tire which is pretty helpful. What size did you end up going with and I assume you are replacing the full size spare with the same then.
Kraken23
Allen
St. Louis, Missouri
2022 BS BL
Yes on replacing the full size spare with the same. I went with the 235s. I looked at the 245s but someone else said it wouldn’t fit in the spare tire area.
235’s fit without issue, 245’s the insulation in the spare tire wheel well needs to be removed.
Looks like either of the Ram standard bases will work fine mounting to that trim piece. I like the look of the Diamond shape better than the round one. I’ll look to see how easy it is run the wire up. I have the traffic module on my wire so I’ll still plug it into the 12v cigarette lighter outlet.
Tigger
Tigger
Illinois
Just installed same mud flaps but I couldn’t resist coloring in the embossed lettering to make them stand out more. Look’s especially good against my black and white OBX. :sunglasses:
Ford Bronco Sport What did you do TO your Bronco Sport today? B03F5FD8-7779-4415-9115-D1C06961396D
I was going to paint mine. Did you use reflective paint? Or do you have a paint suggestion?
