Tracked and eliminated another rattle.
I started hearing another tick, tick, ticking type rattle on rough roads. I started touching panels as I drove to isolate it. I finally traced it to the plastic cover protecting the sensors mounted to the windshield in front of the rearview mirror. I popped the cover off and stuck a couple of pieces of adhesive-backed felt on the left and right sides of the mount where the cover snaps into. Rattle vanquished!
Pigpen
Jon
Nashville, Tennessee
2022 bronco sport
Is that a 2021 or 2022?
Major Kong
Major
Right Here Right Now
Bronco Sport aka "Spark Plug"
considering cab marker lighting
thought that may be a point to access wire connect
need to do exploratory
cover removal easy??
Ford Bronco Sport Tracked and eliminated another rattle. 1659786923653
Yes, I think so. It's as easy as any other panel using those types of fasteners. I wouldn't yank or tug on it (hey now, stay outta the gutter), just use a firm, consistent pull until the fasteners give way.
If you run your wiring into that area you can route it from there across the headliner and down the A-pillar to the fuse panel on the passenger side. That's what I would do.
Pigpen
Jon
2022 bronco sport
It's a 2021, although I don't believe there is a difference between the two for the trim cover I'm referring to. You can see a photo of it here.
https://www.ebay.com/itm/204002677003?chn=ps&mkevt=1&mkcid=28
My reason for asking the model year is thinking that the factory workers may be less skilled in first year assembly. After the first year, there may be fewer problems such as this as they gain experience. Just a thought.
Major Kong
Major
Ford Bronco Sport Tracked and eliminated another rattle. 1659831115818
Ford Bronco Sport Tracked and eliminated another rattle. 1659831094771
Ford Bronco Sport Tracked and eliminated another rattle. 1659832375403
initiate exploratory for roof lights
dig through affected parts inventory
spot headlining
frequencies?
wut?
anyone care to elaborate
sync3 voice commands?
ScareCrow
Burl
Indiana
BS/Badlands
spot headlining
frequencies?
wut?
I think it's for the remote start receiver for Key Fob..........
Just guessing.........
