Waiting room
P-NUT
central Missouri
2017 mkz, 2011 F150 FX4, 1975 MGB
OK, now I'm confused, I just looked at the Ford tracker again and now it says back in production. I viewed another tracker that showed modules and there is a bunch of them. What does blend date mean? There is no date listed. I know I saw built status on the Ford tracker earlier this morning, my wife took a picture of it to send to her friends.
SpartyOn2007
My tracker says in production but has no window sticker.
thekingprawn
Dustin
Kingston, Wa
Webpage caching issues. It will flop back and forth for a couple of days because Ford needs to nuke their web development team from orbit and start over. You can also try the .ca Canadian link, which sometimes seems more stable, or at least has different caching issues.
Blend date is a term used for body on frame vehicles and not applicable to Sports. It will never populate on the tracker for Sports.
thekingprawn
Dustin
Kingston, Wa
Cactusjk
Jeff
Woodland Hills, CA
thekingprawn
Dustin
Kingston, Wa
Wow! I just put my VIN into this and it says Invoiced 16 June and has a window sticker with everything on it!
Not sure what all that means but very interesting.
It means you'll be getting that in production email very soon, and some time in the next 2ish weeks your ride will be built.
Cactusjk
Jeff
Woodland Hills, CA
Amazing! Thanks! Now need to figure out what to do with the one I have!
Little Wild Boar
@thekingprawn had this happen also .. it will eventually settle to built .. do you have tons of numbers in the BCE section? The blend date we believe is for Body on frame vehicles.. which the bronco sport is not .. it's the date they marry the body to the frame.. we think.. what does the other tracker with modules data for status?
Little Wild Boar
The modules data is your next indication once your vehicle is powered up for the first time... Usually between 8 and 17 days after the invoice date ..
What's your Ramp Code on the window sticker and Origin in the app?
Cactusjk
Jeff
Woodland Hills, CA
RA36. Not sure about Origin
P-NUT
central Missouri
Don't know what BCE means, I did look at the tracker you posted a link to and it showed a bunch of modules, I would guess close to 500 of them. I just checked the Ford tracker again and it says built. I still have not received a email from Ford.
thekingprawn
Dustin
Kingston, Wa
It means your Bronco has been turned on. It is alive!
P-NUT
central Missouri
I thought I would get an email from Ford saying it had been built with an estimated delivery date. Am I being inpatient, when I ordered I was told about 6 months and I was ok with that. But it seems that I grow more inpatient each passing week. I can certainly understand people's frustration with the process.
thekingprawn
Dustin
Kingston, Wa
Ford is not timely with their emails. My BS was build on 5/30, but look at the time stamp for the built and shipped emails.
Ford Bronco Sport Waiting room Screenshot (50)
