Post your post lift alignment specs
Bluebaru
Please post your post lift alignment specs here and note what lift you have and if you have camber bolts.
I have Flatout coilovers on order and they now have a rear camber arm, as an available option and I'm debating the need for them. So, I'm most interested in what's happening with the rear camber, when lifted.
https://flatoutsuspension.net/products/bs-lca?variant=42846579654891
Bluebaru
Bluebaru
Thanks! It looks like they did a good job on the alignment. Also, it looks like you didn't get camber bolts, in front, or they just didn't make an adjustment with them and while you are within factory spec, of +0.1 to - 1.5, dead center would be -.7*. I'm guessing that the before and after were both done with the springs on the car and that the before, wasn't pre spring install?
GR3EN
2022 Bronco Sport Outer Banks
Yes both the before and after are with the springs. I do not have cam bolts in the front. Looking at the sheet though I may consider getting some down the road, but as it is at this point it's within spec so there shouldn't be uneven tire wear etc. I'm definitely happy with the angles considering the alterations.
Sean
New Jersey
2022 Bronco Sport Badlands, 2016 Subaru Impreza Sp
Just had my alignment after a 1.5" spacer lift. I didn't get a print out. Tech said it didn't need the camber bolts.
But he also said if I get any bigger tires it will need positive control arms for the rear tires..... anyone else hear a similar story?
Bluebaru
Bluebaru
I think he means what I would call a trailing arm, which would let the tire sit a little further back. I am unaware of anyone making one of those but Ford Ranger lifts makes a 1" rear sub frame drop kit, and a trailing arm spacer kit I think, which would take care of the problems associated with the repositioning of the rear wheels, when lifting.
https://fordrangerlifts.com/shop/ols/products/xn-maverick-bronco-sport-1-subframe-drop-kit-jr1z
