I have none of this
I have none of this
Ford tracker is down again today. The app (even refreshed) is giving me the same info. I expect nothing today.Have you refreshed the screen... 8ve noticed I needed to do that to get current data...
It's on the order tracker app.I have none of this
What's in your ORDER TRACK appI have none of this
All mine happened last evening.. they should be working today.. and I still have not received a email about built... But then again.. built doesn't have a check box either.. no idea what that means...Ford tracker is down again today. The app (even refreshed) is giving me the same info. I expect nothing today.
Ford is trying, but they clearly aren't ready for direct customer interface.All mine happened last evening.. they should be working today.. and I still have not received a email about built... But then again.. built doesn't have a check box either.. no idea what that means...
No, it's not. That's the problem. None of the fields under "rail" have populated any information.It's on the order tracker app.
Nothing under "rail" has anything but ---What's in your ORDER TRACK app
Looks like I'm right there with ya... Invoice 5/27 006270 588/808!My window sticker is now available. Invoiced 05/27/2022. Ramp One: RA4G. Numbers at the top of the window sticker 006270 736/808. It seems like a lot of us are making progress now!
Does your window sticker have the ramp code?No, it's not. That's the problem. None of the fields under "rail" have populated any information.
Ok.. so here are aerial photos from Google maps of my ramp code Wayne Michigan... You will see the yellow things.. those are the actual movable Ramps they use to drive the cars on/off the railcar . The long white things are the actual rail cars.. I believe for SUV's since they are taller they have only 2 levels inside, but ours being a subcompact might fit 3... And here is a link to Union Pacific page about the rail cars used by UP... Video at bottom of pageSo I'm assuming RU2G is somewhere in new Castle, DE... I'll look on maps..
Ramp One says RA4FDoes your window sticker have the ramp code?
RA4G is same as mine... Michigan Assembly in Wayne Michigan where they build the big bronco..My window sticker is now available. Invoiced 05/27/2022. Ramp One: RA4G. Numbers at the top of the window sticker 006270 736/808. It seems like a lot of us are making progress now!
You try refreshingNothing under "rail" has anything but ---
only 1,000x per day since 5/11 ... should I try it again? lolYou try refreshing
