LilbroncoS
Brandon
2021 bronco sport
Visit to the service dept
Hop on the Service Dept/Parts Dept/Cashier Merry-Go-Round
"Passpoints please"
What do you mean no points in the system?
Shows phone app to Final Boss
Ford Bronco Sport What did you do TO your Bronco Sport today? 1651260119125
Did you get the 3 metal studs for engine cover
Major Kong
Major
Right Here Right Now
Bronco Sport aka "Spark Plug"
Confirmed
just didn't make it to the pic in time
Also order the rubberized rear seat back (kit)
Back-ordered
"Don't worry, we'll be in touch"
Ford Bronco Sport What did you do TO your Bronco Sport today? 1651260684530
LilbroncoS
Brandon
2021 bronco sport
I had a similar experience. I went over to pick up my engine cover this morning and the guy at the parts counter had to send me to the cashier because I was using points. She couldn't get things to work, so I ended up using my CC. :rolleyes:
Did you get the 3 screws as well to put cover on
Major Kong
Major
Can you put the rubberized seatback on the base
Normally the answer is no you cannot
However the functionality of the BS will be 99% rear seats folded down
Adapt backing to conform
Concept phase of planning
Introduce Base model BS to rubberized back
May involve exploratory surgery
Noticed zipper on rear seating (imaginary or real I don't recall)
Design substitute for OEM snap fasteners
Considerations
  • Push-pins if possible (most desirable option)
  • Double sided velco
I think it's doable
DaveInSA
Dave
San Antonio, Texas
2021 Bronco Badlands
I snapped on the rear seat back I got off ebay (every where else was backordered and cancelled my order instead of just letting it sit on back order)
Ford Bronco Sport What did you do TO your Bronco Sport today? 1651264440200
Just had to snap the plastic covers off the snaps:
Ford Bronco Sport What did you do TO your Bronco Sport today? 1651264467679
Ford Bronco Sport What did you do TO your Bronco Sport today? 1651264474405
Oh, and washed it and used some turtle wax cermaic spray on it.
Major Kong
Major
Looks like a zipper
Feels like a zipper
Smells like......
Didn't pass the sniff test
What the heck is this
Looks like it's meant to open for fabric removal
Anyway seems solid enough back where the snaps are located
Plan A
Placement of holes aligned with rubber backing snaps
holes sized for push pins
I think I'm on track gang
Ford Bronco Sport What did you do TO your Bronco Sport today? 1651266118751
LilbroncoS
Brandon
2021 bronco sport
Looks like a zipper
Feels like a zipper
Smells like......
Plan A
Get all your peices. Place the mats on seats exactly where you want. Mark through holes with sharpie.. drill out. Add snaps. Call it a day ?
LilbroncoS
Brandon
2021 bronco sport
So i hand buffed all the piano black side pillars. Been meaning to since i got it. Some how the dealer scratched it all up before i ever seen the bronco... Didnt take long. They look glossy smooth finally. Will edit with pic in a bit. Got windy
Major Kong
Major
I got two small things done. I installed the engine cover (that begs for a custom touch to come later) and swapped out Mr. Big for Lil Stubby. After all, it's not the size of your antenna, it's the motion of the ocean, or something like that.
Ford Bronco Sport What did you do TO your Bronco Sport today? Engine cover
Ford Bronco Sport What did you do TO your Bronco Sport today? antenna
Meet Lil Stubby
Ford Bronco Sport What did you do TO your Bronco Sport today? 1651270350162
