On my '25 1.5L (cold engine), when I unlock the and open the door, I hear a whirring noise at a constant pitch. It will slowly increase/decrease in pitch every ~60s and remain at a constant pitch. Even if I close the door and lock the vehicle it continues to run, but it does eventually stop after a few minutes.
The only thing I can think of is the low pressure fuel pump, maybe associated with a leaking fuel injector test? If it's the low pressure fuel pump, why would whirring noise come from under the hood when the low pressure electric fuel pump is in the tank? I thought I read the '25 high pressure pump is mechanically driven.
I read the other possibility is the coolant pump or headlight condensation fans.
UPDATE: I confirmed it's the headlight fans.
