Water (tiny drops but constant) spraying out of the windshield defrost vents
kyle.miller_07
Kyle
Gainesville, FL
My wife’s Bronco has water (tiny drops but constant) spraying out of the windshield defrost vents. A/C is ON, recirculate is ON, defrost is OFF. Noticed we could hear a sound similar to water gurgling while it was raining then noticed the light spraying.
magicbus
Nantucket
Rivian R1T, Volvo XC90 Hybrid
Sounds like a clogged condensation drain hose. I haven’t noticed mine but they are usually pretty obvious because they hang straight down towards the road. Try running a wire up it or tracing it back up under the hood and disconnect it to clear the clog.
Ford Motor Company
Dearborn
Bronco, Bronco Sport
Good morning! If you send over a DM with your VIN and Ford dealer info, I can look into your concern on my end.
mikeyncc
Durham NC
Agree, a drain in clogged...
kyle.miller_07
Kyle
Gainesville, FL
Thanks everyone, gonna locate that drain tube and try to clear it ASAP.
dwizzy
Try turning the recirculating off. Otherwise, condensation builds up.
cprcubed
Patrick
Parker, TX
Any condensate should still drain regardless of the setting, hence the need to check the drain line. Cheers!
