Vehicle Network Communication Error???
jake4042
J
Given the collection of errors, if the BS required a jump start, it probably needs some time for the battery to be charged. Electrical errors like this, especially in this quantity out of the blue, generally means the battery is low on charge or possibly bad.
Yeah, the battery might have drained due to the original issue that occurred while driving.
I still can't believe how Ford is putting its customers out like this. This is my first Ford and my last. I understand new cars break but I have never had a brand and dealership say hey your car isn't working, you are on your own for transportation for 2-6 weeks until we can get around to checking your car.
johnardsg
johnard
Texas (previously from PNW)
2021 BS BigBend/2011 v6 Rav4
I just had this error 10mins ago, luckily it happened right when I parked at my garage. My battery is not even a year old and I just had the PCM/BCM recall done. I disconnected the battery and will check it later to see if it starts back normally :(
Humper
Mick
Oklahoma
Yesterday similar issue with zero power, everything dead, i jumped my BS after wiggling the ground cable which was loose and it started up, but I had fault codes all the way home, the ground cable near the inner fender was loose.
Put battery on charge for a few hours last night and it fired right up with no faults.
Check your ground cable.
